Over heating posted by mlimage on June 22, 2008 at 10:50 AM
listen dude im the over heat king my car use to run so hot satan envyed me. First place you should most difenently check is leaks. Once that temp gauge get about 3 quarters of the way get out and see if your leaking. Check the back of the fire wall real hard those heater core hoses are notorious for leaking. 2ndly Check that radiator asap I had two cloged radiators that had me running hot. A radiator shop should be able to handle the flow test and professional flush for about $60 bucks. also if those tanks on the radiator are plastic make sure they are not cracked. I dont even have a themostat in car I wont be sitting still for 10mins at a idle. please make sure that the fan is getting good rotation those clutches can go at any time no warning.
